More 700R4 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2011, 10:47 AM
First... I read the thread about the 700R4 lock up wire diagram, but I am unsure if that is all I need to hook up to make the trans work properly.
Second... What does the 87 pin go to?
The trans is staying in the original truck, but I am swaping engines and going with a carb. I want to do away with as much computer stuff as I can.
I am swapping the 6.2 out of my 89 Suburban for a 350.
Any help would be greatly appreciated.
Doug
Old 10-02-2011, 11:04 AM
Just a thought... I have to buy a new torque convertor for the gas engine anyway, should I try to find a non-lockup convertor and just do away with the electrical? Is that even an option?
Also I have alot of th350 parts. Do the th350 and 700R4 use the same flex plate?
Old 10-03-2011, 05:03 AM
SSedan64's Avatar
Since you're doing away with the Computer controls, you'll need to buy a Lockup Kit or DIY.
http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
http://transgoonline.com/products.ph...dcountview=Yes
Pin 87 ??
You can convert the 700R4 to use a Non-Lockup TC. Requires swapping the TCC Apply Valve in the Pump & removing Check Valve and O-ring from Input Shaft + a Non-Lockup TC.
Many 350s & 700R4s use the same Flexplate.
700r4 questions jeepguy48 Transmission - Rearend 6 11-10-2009 02:41 AM
700R4 questions Gladis Transmission - Rearend 5 04-30-2007 06:30 PM
700R4 questions 455c-10 Transmission - Rearend 10 08-11-2005 03:19 PM
700r4 questions BIG DIXIE Transmission - Rearend 3 01-11-2005 07:55 PM
700r4 questions please help av8300zx Transmission - Rearend 2 06-09-2002 09:24 PM
