more 95 gmc jimmy woes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2006, 09:21 AM
need some advice for my 95 gmc jimmy. the new problem is something with the heater/ac blower I think. when your running down the road, everything works great, when you pull into the driveway, and shut it down, and pull out the key, the blower still runs, unless you turn the dial to "off" otherwise, it will blow with the key out of the vehicle. Could this be my relay?
another problem: engine cold= starts right up
engine hot= hard to start, have to crank it over, shut off the key, roll it over again, shut off key, roll it over again, and so on, until it finally fires, usually on the third or 4th try. Any ideas? fuel pump?
Thanks in advance for any help
Jim
Old 07-09-2006, 09:29 AM
It could possibly be a relay, however the relay should not be getting any power with the key off. Sounds more like an acc relay or whatever else that supplies power to the hvac relay.
Old 07-09-2006, 09:32 AM
where is that relay located? can it be tested?
Old 07-09-2006, 12:52 PM
we have relay testers at work (I think its from Bosch), however its easier to just replace it.
Old 07-09-2006, 04:24 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Are you talking about the blower motor relay or the Engine fan relay? The fan will remain on on some after the key is shut off..The blower should not..
If it's the blower, you have a welded contact or miswire..
On the start up situation, If fuel is up to par.. have the codes checked..sounds like a sensor is failing .
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
need some advice about a 95 GMC Jimmy ChevyJim Suspension - Brakes - Steering 14 04-23-2006 09:18 AM
need help finding TDC and some other things on my 95 GMC 350 warren35095 Engine 2 04-28-2005 10:19 PM
1985 GMC Jimmy astrophel General Rodding Tech 2 12-08-2004 06:04 PM
fuel relay location in 95 jimmy sharee Introduce Yourself 0 08-08-2004 09:44 AM
