More boost less horse power? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2009, 06:21 AM
heres my problem forged 383 sb 8.8 comp 671 with 2 edelbrock 650cfm carbs. about 7 lb. boost made 475rwhp in 69 camaro with 700r4 3000stall. i flipped the pullys 38/34 to 34/38 boost went to 12lb rwhp dropped to 360? running leaner as well after rejetting carbs to max regapped the plugs got it up to 435rwhp, any help on this one?
Old 10-31-2009, 09:54 AM
In rough numbers, you've gone from about 10% underdrive to about 12% overdrive.
1. It takes more HP to spin the blower harder.
2. The 12 PSI air is hotter than the 7 PSI air.
To get a flavor for the HP required to turn the blower, research the blower displacement and use the crude formula; Flow X PSI divided by 1500 = HP requied.
This doesn't address other factors including air temp, fuel specific gravity, the effect of the amount of fuel induced cooling to the output air, ignition timing, etc., etc.
Austin Coil has a blower dyno. It's unlikely a blower dyno would be avaialble to you and I since the cost is high and the market to recover cost and make a profit is marginal.... very marginal. It would also create a marketing hurdle for blower sellers as they (might) would be forced to test and publish results
Old 11-01-2009, 07:07 AM
Thanks. Sorry did not mention i have a meth. injection set up also have boost retard on the ignition pulling 1 degree per lb of boost. last test after checking & re-gaping plugs got back almost 100 hp. still less than 7lb boost best hp test. had not considered the head gasket but don't think that is an issue. after talking with a couple of guys who run blowers the consensus seems to be i may have exceeded the fuel system capacity? I have a 140gph pump with a stock fuel line regulator is set at 8lb fuel pressure. i appreciate the help
Frank
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
300 horse power 355 70 nova Engine 9 02-19-2003 11:38 AM
Horse power and Torque HELP PLEASE!!! 70 nova Engine 2 02-18-2003 10:57 PM
pulleys does it give horse power or torque 70 nova Engine 2 02-18-2003 10:59 AM
