The point I am trying to make is you don't look at a camshaft catalog and say I want a 230/236 duration camshaft with .490 lift I/E ground at 108 LDA. You want to think about where the 4 cam timing events need to occur and the LDA falls where it may. Where the 4 cam timing events need to occur may be far different than the camshaft with a 108 LDA out of the catalog.
One HUGE variability in LDA is just the exhaust. I think in trying to understand camshafts this is not the area to start in or even make generalizations. I think you need to start with reading the theorys and dynamics on the 4 timing events the camshaft is controlling. |
examples the same intake lobe and the same exhaust lobe, the difference being LSA (lobe center). Same lobes two different camshafts. What would be the differences if installed in otherwise identical engines? **************************************** LOBE CENTER: 108 deg. OVERLAP: 59 deg. g. THE ABOVE TIMING IS CHECKED AT .007 The following timing is taken at .050" INTAKE DURATION: 221 deg. OPEN: 2.5 BEFORE TDC CLOSE: 38.5 AFTER BDC EXHAUST DURATION: 232 deg. OPEN: 44 BEFORE BDC CLOSE: 8 AFTER TDC ************************************** LOBE CENTER: 112 deg. OVERLAP: 51 deg. THE ABOVE TIMING IS CHECKED AT .007” The following timing is taken at .050" INTAKE DURATION: 221 deg. OPEN: -1.5 BEFORE TDC CLOSE: 42.5 AFTER BDC EXHAUST DURATION: 232 deg. OPEN: 48 BEFORE BDC CLOSE: 4 AFTER TDC |
I agree with Rick, and to be honest I think the tone of this thread has been pretty suspect from the beginning but that's another discussion
Looking at the valve timing events the differences in the two camshafts
become evident. Basically what the cam grinder did with the 112 LSA cam was retard the intake lobe 4 degrees and advance the exhaust lobe 4 degrees. Using identical lobes the cam grinder was able to tune the engine for different performance characteristics. Studying the events of each camshaft will illustrate the differences. To mention a few; the camshaft ground with 112 LSA has the overlap reduced by 8 degrees, this will improve idle vacuum. In addition the 112 LSA cam has a intake valve closing point 4 degrees later, this will reduce dynamic compression to make the engine a little more detonation resistant. Killerformula, this is basic camshaft design, remember what xntrik said ”This is a learning exercise”. We don’t think twice about advancing or retarding a camshaft to achieve desired engine performance. This is much the same, the difference being we can degree a cam at any time but once the LSA decision is made and the cam is ground it is set in stone. **************************************** LOBE CENTER: 108 deg. OVERLAP: 59 deg. g. THE ABOVE TIMING IS CHECKED AT .007 The following timing is taken at .050" INTAKE DURATION: 221 deg. OPEN: 2.5 BEFORE TDC CLOSE: 38.5 AFTER BDC EXHAUST DURATION: 232 deg. OPEN: 44 BEFORE BDC CLOSE: 8 AFTER TDC ************************************** LOBE CENTER: 112 deg. OVERLAP: 51 deg. THE ABOVE TIMING IS CHECKED AT .007” The following timing is taken at .050" INTAKE DURATION: 221 deg. OPEN: -1.5 BEFORE TDC CLOSE: 42.5 AFTER BDC EXHAUST DURATION: 232 deg. OPEN: 48 BEFORE BDC CLOSE: 4 AFTER TDC Last edited by automotive breath; 02-04-2007 at 12:30 PM. |
a math problem. That's the kind of things that makes this confusing.
Post #1 K I S S 2 cams. Identical symetrical lobe shapes, durations, lift, etc. One ground on 108* LSA one ground on 112* LSA. What is the difference when installed in an engine? ************************************************* OK forget in the engine. What's the difference lying on the table like I said in post #6. quote= These 2 chunks of bumpy cast iron are lying on the table..... what's the difference between them? |
Sometimes "the way you look at it" makes it seem totally different. It is pretty hard to distinguish between what is IS and what it DOES. Hang on. |
post # 1 , or # 6? http://en.wikipedia.org/wiki/Subterfuge Subterfuge can be any deceptive stratagem or manoeuvre designed to take advantage of an opponent. Last edited by xntrik; 02-04-2007 at 08:40 PM. |
Well this thread has gone into the toilet. I'm going to lock it, edit out the personal stuff, and leave it visible for the technical value.
BSE Racing Engines |
| help with a cam choice | powerrodsmike | Engine | 24 | 07-30-2006 10:42 PM |
| Comp cams took care of failing cam | TurboS10 | Hotrodders' Lounge | 12 | 01-08-2005 07:15 PM |
| Cam selection 400 sbc help | gleveric | Engine | 12 | 11-16-2004 08:28 AM |
| More issues....lets talk cam failure | TurboS10 | Engine | 23 | 09-28-2004 11:51 AM |
