Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More Cam Tech, close LSA
Old 02-01-2007, 07:11 PM
CptKaos CptKaos is offline
opinionated old fart
Last journal entry: Sheetmetal
All else being equal and assuming enough lift and duration to flow properly the lower LSA would create less engine vac at idle, need a higher idle setting and a higher stall converter but would capable of more torque and horsepower in the mid to upper RPM range.
