Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - more castor from '55 chevy 210
Old 04-17-2005, 11:07 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
best thing i can tell you without seeing it is to measure ,measure, measure .
make sure u got a level area measure the frame then go outward to the suspension i guess its like a trianglization .
try going across the front wheels front, back, top ,bottom .
if that dont work front end machine will give you a good idea.
so hard to do without seeing feel free to bounce ideas off me if you like.
slowride 66
"SlowRide66"
"Illegitimis non carborundum"
