Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More door panels..
Old 09-05-2009, 07:42 AM
79 Cheyenne's Avatar
79 Cheyenne 79 Cheyenne is offline
More time than money...
Originally Posted by APalusky
I would like to build some door panels for a 37 Ford Tudor. I want to add a 6 1/2" speaker to it, but don't want it to be stuck inside the door. I was thinking of something like in the picture. Do you think I could use 2" rigid styrofoam and taper it down?? The door pull I was going to use 1/2" plywood on top of each other to make the pulls. In the end where it bends down. I want to put in the switch for the power windows.. Will the styrofoam work??, or do you think glass is better??
I would suggest glassing over a simple frame. Very simple and you can make it look fantastic without running into trouble when you install it. Check out some of the youtube video's. These kids are something nowadays!
