Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More door panels..
Old 09-06-2009, 08:39 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
That should work fine, but if I were you I would not use 1/4" plywood as a base. If you ever try 1/8" PVC foamboard (Sintra, Komatex, Celtec) you won't ever use plywood again. It forms easily with regular woodworking tools and moisture will never be a problem.
