a more efficient solution - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2005, 01:07 PM
hotrodgrasshopper's Avatar
New Member
I'm getting back fire under my hood when ever my trany down shifts. My engine also sounds like the timings off. "so get it timed, duh," But it was timed no more than 3 weeks ago. Do i need to get it timed every month or is there a more efficient solution?
i have a late 60's 350 with a bore and stroke. "not sure how much of each."
I have miss matched wires "complimentary of the shop i took it to"
The top end was completely redone.
New plugs are in.
Old 03-17-2005, 01:15 PM
firestone's Avatar
http://teamrfc.gospelcom.net
My guess would be that carb is bad. I have a friend with a car that is acting very similar, and a couple of shops have recommended a new carb. Just an idea.
Adam
Old 03-17-2005, 02:34 PM
rick458's Avatar
Wookie
you may as well get a new set of wires thathave the same impedence
and make sure they are not crossing, Then look for air leaks
Carb back fires generally a lean condition.
make sure your valves are set right as well.
BUT just do one step at a time
how to build a really fuel efficient SBC for gas at $5/gal.??? Berliner Bel Air Engine 42 07-04-2005 11:36 AM
Vacuum solution needed seanbgun Engine 7 02-16-2005 01:53 PM
home anodizing??? hmmm General Rodding Tech 13 06-28-2004 04:48 AM
Fuel Efficient Carburetor JohnyR17 Engine 12 03-11-2004 12:24 AM
Cleaning Solution DTL504 Engine 2 11-09-2003 06:09 PM
