More ethanol - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2007, 06:05 PM
AllSteel34's Avatar
More ethanol
More ethanol in our gas soon...
http://www.arb.ca.gov/newsrel/nr061507.htm
Chris
Old 06-15-2007, 07:21 PM
bullheimer's Avatar
NEVER use credit cards!
just wondering if that is good, cause your mileage goes DOWN with alcohol since there is less energy in it than in gas. saw a deal on the boob-tube where cars on E85 got WAY LESS mileage.
Old 06-15-2007, 08:56 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
I'm not so sure about the lower milage. I made a run from my home to Houston, SE side, about 4-5 hours, a few months ago in my '05 Chevy 3/4T 4X4, 6.0L. I got a full tank of cheap gas, 87, before I left. Got there and checked the milage computer, 13.8 MPG. Before I came back I stopped at a Shell station 300 yards from the main gate of the refinery. Switched to 89 octane and on the pump a sign read "This fuel may contain up to 10% ethanol". Made the run back the same exact way, got in the driveway and hit the milage-16 MPG. Thats 2 miles a gallon!!! I figured OK I went to the 89 octane. Went to my normal local station and got a tank full. No change in mileage from what I was getting before I made the trip. OK a Shell station is in the next town. Went there got a tank of 89 octane but there was no sign on the pumps about ethanol. Ran that tank through and got the same result no differance in mileage from before I made the trip and got that one tank of fuel. If you can figure it out tell me what gave me 2 miles a gallon on one tank of fuel because I've never been able to do it again and nobody I've talked to can figure it out either. The only thing I can think of is it's got to be the 10% ethanol that made the differance.
Old 06-17-2007, 09:53 PM
My mom's 2000 Grand Marquis gets more than 10% better gas mileage on Chevron 87 than it does with Wal-Mart 87. They don't have to warn us about ethanol in Louisiana, but I figure cheap gas is just that, cheap gas. My '79 Suburban won't even run smoothly on the cheap stuff.
Old 06-19-2007, 12:15 AM
Bluepen, which way was the wind blowing the day you made your trip from Cove to Houston?
Old 06-19-2007, 06:02 AM
crash70rs's Avatar
Last journal entry: Going Slow.. and steady?
Did you tend to drive uphill vs. down hill? I tend to see a 2-3 mpg difference when driving from the here to NYC and back. I think I spend more time chugging uphill coming "upstate" but I may be wrong. My stepdad thinks its because my car like Long Island better than rochester.
Old 06-19-2007, 08:00 AM
Hippie's Avatar
Last journal entry: HEI comparison.
What's all the fuss? I have used 10% Ethanol 89 Octane from a discount station for 12 years and a few hundred thousand miles in everything from a stock '62 283 Impala to our 2004 Malibu 3500. I used it occasionally prior to that and had one vehicle that ran noticably better on the Ethanol than on the regular. Have never had any fuel issues. It's been the only station in town for 12 years and the 89 is normally 10 cents a gallon cheaper than regular 87 around here. I noticed a few years ago that their gas came out of the same tanker that delivered to the big name brand stations in the surrounding towns............ it's a local distributor and his tanker has a VERY distinctive paint job, you can tell it's him a mile away. My old 200,000 mile '94 LeSabre was getting 29 MPG Hwy running 70-75 MPH and 24 average on 10% Ethanol. The wife's Malibu is averaging 33 MPG City/Hwy.
Old 06-19-2007, 12:43 PM
tipically the farther south you go the better milage you get .....maybe its just because that WVa gas sucks and a couple of local chains my ttruck tends to diesel on there gas
Shane
Old 06-19-2007, 12:49 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I didn't see anything that said how much more ethanol they're going to mix? I didn't notice any change in mileage last year when they made the change from MTBE to ethanol. You might not notice much, if any, change until you start using ethanol in significant quantities.
This is because as you get closer to the equator the centrifugal force of the earth rotating tends to "lift" a little more weight off the vehicles tires, therefore causing a reduction in rolling resistance and requisite increase in fuel economy.
Old 06-22-2007, 11:20 PM
with the malibu that we usedto have 2001 3100v6 got 26-27 around here in NC after driving around on NC Gas 34.9 iirc
Shane
Is ethanol really the answer? oldred General Rodding Tech 49 07-07-2006 04:56 PM
Ethanol Fuel ChevelleSS_LS6 Engine 53 02-02-2006 02:39 PM
Ethanol? chrisflock Engine 8 05-29-2005 08:53 PM
Will 80% ethanol blend hurt my engine? brian12c Engine 23 04-03-2005 09:36 PM
useing ethanol streight 86 Fiero SE Engine 3 03-25-2005 12:56 AM
