More h.p. needed for my Ford inline 6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 07:41 PM
67FordFalcon's Avatar
This is what I'm starting with
Last journal entry: Putting the engine back in . . .
how do i pump out more horses in my I6 200?
Old 02-23-2012, 08:10 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Turbos work well.
Old 02-24-2012, 10:26 AM
dinger's Avatar
Start out by asking a question that people may want to help you with in the topic line. Topic-Dumb Question will not get you a lot of response. People have better things to do. I will edit this for you. We are going to assume this is in regards to a Ford engine by the name you chose to use. Clarity will get you everywhere.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-24-2012, 10:34 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
When you get a chance, do visit the Bulletin Board at Inliners International. Lots of good info and reading there. Good luck!
Old 02-24-2012, 03:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Go to THIS Wiki page for links to inline 6 info. Some links are Chevy-centric, others have parts and info for Fords as well as other inline engines.
A search here using the Google Custom Search at the top of the page will get you threads on the subject as well.
Good luck.
Old 02-25-2012, 12:28 AM
thx for the links, will check them all out.
Old 02-25-2012, 06:44 AM
Crosley's Avatar
Wiki Edits: 1659
This Ford Six Forum is very useful.
Also Classic Inlines , has many performance parts, even an aluminum head for the small inline six.
My 1962 Falcon with 200 CID inline 6 engine and C4 runs 15.40s at 87 mph in 1/4 mile. Engine is a mild build up
Ford inline six to 2300 inline 4 swap. 74chevyflat Engine 3 05-20-2010 10:12 PM
Ford Inline 6 4.9L with only 145 hp? GnrYmr Engine 13 12-02-2009 11:06 AM
4.9l ford inline 6 wmbibb Engine 4 04-18-2009 12:37 PM
Ford Inline 6 CustomFord Engine 3 02-03-2003 11:25 AM
1948 plymouth inline flathead 6 cyl info needed 1948PlymouthSpecDel Engine 7 12-31-2002 08:43 AM
