more horsepower from a stock 429 v8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2010, 06:22 PM
what do i need to do to get more horsepower from a 1973 ford 429 v8 engine.
Old 03-02-2010, 06:46 PM
techinspector1's Avatar
Wiki Edits: 326
Hey Mike. Any motor out there is just an air pump. If you can get more air into the motor on the intake side and more air out of the motor on the exhaust side, you can make more power. You can also squeeze the air that is coming into the motor a little tighter with a higher static compression ratio and make more power.
You should know though, that it isn't a one-way street. For instance, any cam that you bolt into the motor will only be good for a range of about 3,500 rpm's. In other words, a stock-type cam might make power in the motor from idle to 4,000. A slightly hotter cam might make power from 1,500 to 5,000. At that level of power, you could still use your stock torque converter. Hotter yet might make power from 2,500 to 6,000 and would require an aftermarket, looser converter that would allow the motor to rev up higher with the transmission in gear. You need some way to get past the mushy part of the rpm range from idle to 2,500 with this cam, so you use a looser converter and a shorter gear (3.73, 3.90, 4.10, 4.56, or whatever). As the numbers get larger, the gear is called "shorter". As the numbers get smaller, the gear is called "taller".
You can also make more power by force-feeding the motor with more air than it would normally suck in, by using a supercharger or turbocharger or other means of pressurizing the intake side of the motor.
Another way is to bolt on a Nitrous Oxide system. This increases the amount of fuel going into the motor and provides additional oxygen to burn the additional fuel.
So, as you see, there are many ways to "skin a cat". In the end, it all depends on the amount of power you want, where you want it (low rpm's, high rpm's, whatever) and how much money you have to spend.
If you'll share with us what kind of vehicle you want to put the motor in, what kind of transmission you want to use, what the purpose of the vehicle will be and the type of fuel that is available to run on in your area, we'll try to be a little more specific as to the mods necessary to get where you want to go.
Old 03-02-2010, 07:23 PM
ericnova72's Avatar
More for Less Racer
One of the biggest bugaboo's with the Ford 385 series engine family(429-460) is the fact that they came from the factory in the early 70's with an 8 degree retarded timing chain set. This was Ford's "fix" to meet the new emissions standards set by the government. Replace it with a standard performance timing set and you will see roughly 25 hp gain without changing anything else. This is a well known fact in Ford performance circles, and I have seen it myself with a '73 460.
Old 03-02-2010, 08:26 PM
Wiki Edits: 326
eric speaks the truth. Order a timing set for a '68-'71 429 engine.
Old 03-03-2010, 07:08 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
...Look for a set of D0VE heads, too...
Old 03-03-2010, 08:22 AM
yup,,,
timing chain and likely/maybe a new (rebuilt) dist to go with it...
"dead on" exact ign timing control is a must have to make best power....
what vehicle is the motor in and what tranny and rear gears????
you might be actually wanting more TQ not more high rpms HP...
TQ= more "push you back in the seat" fun on the streets...
HP=WOT quicker at the strip printed on the time slip...
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 04:36 PM
1992 GMC Sonoma will stock tranny hold up to V8? sonomadog Transmission - Rearend 4 11-01-2009 01:26 PM
Questions on V8 s-10 suspension for V-8 beetle zbhover Suspension - Brakes - Steering 6 11-01-2009 01:04 PM
Bigger Engine For 68 Falcon Jim69Mustang Engine 4 10-07-2007 08:08 PM
Holley 750 VS on stock 350ci 360Camaro Engine 8 09-13-2005 08:12 AM
