-   -   more info about this rearend (http://www.hotrodders.com/forum/more-info-about-rearend-224524.html)
splicr30 09-30-2012 10:31 AM
5 Attachment(s)
i believe its a ford 9" from about 1957 ..anyone have any info...
BOBCRMAN@aol.com 09-30-2012 11:03 AM
Try this Kevinstang's Ford Nine Inch Differential Page +
big gear head 09-30-2012 12:03 PM
That is a '57 to '64 Ford 9 inch rear end. Should be about 59 1/2 inches wide over all with 28 spline axles. These are the weakest of the 9 inch Ford rear ends, but are among the best looking. They are more popular with the street rod guys because they are smooth on the back and most street rods don't need all that much strength.
S10xGN 10-01-2012 08:19 AM
That first pic looks like a socket will fit the bottom bolts (even though one is not visible), wouldn't that make it an 8"?
Russ
big gear head 10-01-2012 09:26 AM
Neither of the 2 bottom holes are visible in that picture. It's a 9 inch. I've had many of these older 9 inch rear ends, and I've got one sitting outside my shop right now that needs to find a new home. That's what is called the WAR case, even though this one is marked WAA. I've had a few that were marked WAB too. This was the weakest of all the 9 inch cases, along with the housing. Most of these had 3.10 or 3.56 gears in them.
cobalt327 10-01-2012 03:20 PM
Here are some links to Ford 9 inch info.
