More Info, High RPM to Shift on 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2003, 12:49 PM
New Member
When I last left you, I thought the transmission that I had would not shift out of first gear. Well it does shift but I have to get to a high rpm before it does, and it will go on to third at high rpm. Do you think this is an adjustment on the TV cable. I have worked with it some and nothing seems to help it. The original problem was that the splines in the torque converter were ripped off. Put on a new converter and it will move and shifts real hard. Any more info is truly appreciated.
Thanks
Old 11-25-2003, 03:18 PM
Sounds like your governor may be sticking. But the TV calble is also a possibilty. Did you check the pump and other internals to make sure there was no debris inside when you replaced the converter?
Old 11-25-2003, 05:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I did not fully explain the fail safe syustem on the 700 in the other thread, sorry.
when in fail safe the tranny shifts like the TV is at MAX pull.
If the TV is not set at minimum corrrectly the check ball will seat and put the tranny into the fail safe mode.
There should be tension on the TV cable at idle NO slack at all. Full pull of the TV cable at WOT usually does this if the cable to throttle arm geometry is close
Old 11-25-2003, 05:44 PM
New Member
I have worked on adjusting the TV cable. It is shifting a lot better, but not quite right. It shifts to second at around 20 mph, and then to 3rd at around 40 mph. It never goes to overdrive, but I can feel the converter lock up. I am wondering if there is something in the governor. I am gonna drive it a few times later this week, if it does not get any better I am gonna pull the cover to the governer and clean it all out. It probably will not hurt to pull the pan back of and changed the fluid again. All the splines in the torque converter were completely gone. Does this sound like the correct action?
