Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More Mustang ll Questions...
Old 05-23-2009, 08:42 AM
redsdad redsdad is offline
Will I ever get it done?
Last journal entry: Driver's Door
If the cotter pin is fully engaged in the slots of the castellated nut once it is tightened to proper torque specifications, then the washer is thick enough. If the cotter pin is exposed to half or more of its diameter, you need a thicker washer.
