I think you should read up on spraying cause there's a lot you can learn. At this point it sounds like you're not aware of the importance of the right size tips. And with HF guns it's ok with primer but to have clear lay out good you'll need to over reduce it or hammer it on. If you somehow get a glassy look it will have trapped solvents or run. If you use a better gun ( doesn't have to be the best) you will be able to achieve that gloss easier due to better atomization, without runs or trapped solvents.
