Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - more paint woahs
Old 08-16-2012, 11:20 PM
Lizer Lizer is offline
Originally Posted by cutthroatkid View Post
Ok so...I have 2 hf cheapo purple guns&the 2 gun so called pro kit from hf&Ive been using the larger gun on practice panels.The issue Im getting is there seems to be fine droplets kind of like a splatter..I get no runs but I get an almost orange peel it looks as if its orange peel but real fine&its smooth to the touch.Im thinking Im not waiting long enough between flash&the droplets are just cause the gun is dialed in Im running the
Gun@35psi@the regulator on the gun&35on the 33gal compressor I have all of this is probably wrong please help.
what is your PSI with the trigger pulled? If you're running 35 on the gun regulator AND the compressor regulator your PSI when the trigger is pulled has got to be way too low...so low it's barely even atomizing the paint.
