I get the HF purple guns with 1.4 tips all day long. The 1.5 tips are the hard ones to find. They spray fine. Depends on the products used. For base coat reduce the presssure and crank it up for the clear. You can tell which size tip by the part number on the box. The 1.4 and 1.5 tips use different part numbers. Somebody is using those guns for paint jobs, the guns in stock at HF get depleted quick.
