Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - more paint woahs
Old 08-17-2012, 12:49 PM
cutthroatkid's Avatar
cutthroatkid cutthroatkid is offline
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Originally Posted by cyclopsblown34 View Post
You said the other day your compressor came unplugged. If that's the case, I'm guessing it's a little 110V or maybe 110V/220V 33 gallon upright oilless compressor. By the time you've sprayed for a minute with that gun, your compressor is already behind in air delivery and you're probably not getting full atomization. See what your SCFM or CFM rating is on your compressor. you need probably 14CFM for those guns. if your compressor is less than that, you'll have some of the problems you mentioned.
Motor-Engine: Drive Typeirect Drive Voltage:120 volts Horsepower:1.60 hp SCFM Delivery: SCFM Delivery At 40 psi:6.3 SCFM SCFM Delivery At 90 psi:5.1 SCFM Tank: Compressor Tank Capacity:33 gal. Compressor Tank Pump Style:Oil Free Maximum Compressor psi:150 psi
