Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - more paint woahs
Old 08-17-2012, 01:59 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
There can be lots of things wrong that are causing you problems. Do you have a good water filter on the compressor? Make sure all the fittings on the HF gun are tight, they throw those things together and you can get ones that have loose fittings. Always make sure you don't have a clogged vent on top of the cup. For base coat you want something like about 25 psi and you want something like 40-45 psi for clear. You can get the clear to flow with the HF gun.
