more paint woahs - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-18-2012, 01:42 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Good question but my reason not so Good...my compressor is up ona work bench that runs the length of a wall&I have a step ladder to get up there to it...Im a short sawed of sob@around 5ft5 &I have a lifted truck&my old lady had to take it to get in the truck shes only 5ft
  #32 (permalink)
Old 08-18-2012, 06:02 PM
I have a Campbell Housfield with 4hp and 13 gallon tank, It does ok with the cheep husky gravity feed gun for small stuff (a panel, priming, or jambs).
For the bigger stuff, (2 or more panels, and all over) I use a Croix turbine and accuspray model 60.
For a DIYer, at home mabe it would be less expensive to get a bigger compressor, with at least 80 gallon tank, 2 cylinder, 5 hp, 220 volt.
The main thing is to get the most air flow volume/min/psi. that you can afford. You want a high volume, at a decent pressure.
If you have a compressor that can keep up with 20+ CFM at 40 psi (at your altitude) it will run just about anything you have.
I keep the regulator on the compressor set at 8bar= about 120 PSI.
  #33 (permalink)
Old 08-18-2012, 11:00 PM
two cups of tea
Wiki Edits: 2
Well I just dropd a ton of cash on getting this shop up...pretty big 24x36 looks nice&all of the body tools &such so gonna have to make this compressor work for awhile.
Went&looked@a few today EXPENSIVE!Theres a 6 mo layaway@our local farm&tool supply so gonna go put something down&a comp&a few other things.Since Ive welded my first patch panel in Ive been in love with this stuff Almost forgot about making things go fast.Gotta finish up my g-body&I got a old bike Im gonna build then Im off to find me a gasser
  #34 (permalink)
Old 08-19-2012, 01:57 AM
It crazy but keep your eye out on craigslist every once in a while tou can gind a commercial. Unit for pennies on the dollar of what it originally cost
Will paint peel if I only paint firewall? Should I wait to paint whole cab? jsm1847 Body - Exterior 10 07-10-2012 06:28 AM
The ultimate budget paint job thread /w pics (rustoleum paint) Project89 Hotrodding Basics 130 04-24-2012 12:19 AM
prepping my car now for paint. questions on how far to sand existing paint ((sr)) kelly Body - Exterior 3 07-15-2009 11:49 AM
power disc woes...or not so much woahs... usmcsawgunner Suspension - Brakes - Steering 4 02-04-2009 01:18 PM
