more primer questions! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2007, 05:30 PM
After struggling with mastering welding sheet metal i am finally getting ready to start priming and sanding. I have got kirker epoxy primer and kirker perfect prime 2k. I know i am suppose to epoxy the metal before filler. Do any filling that needs to be done, then use the perfect prime for filler primer? After sanding, how many coats of the perfect prime and sanding should be done?? or is it mainly just a judgment call on how straight the body looks?? Also, Either can be used as a sealer. Which would work better? Also do you sand the sealer coat? Has anybody used the kirker primer, Is it ok. Also can you spray dupont hot hues paint over it?
Thanks guys
Aaron
Old 02-25-2007, 06:25 PM
primer question
You will have to ck the spec sheet of primer you have and do what they recommend as far as sanding, also where you bought the primer from can tell you if dupount paint is compatible.
Old 02-25-2007, 08:49 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Hopefully your metal is at the point that it will only take a smidge of filler to fix any small defects..put your epoxy on and then fill and then use the 2k to block with..guide coating and blocking takes as long and as many coats as it takes until you are happy with the result....
Then shoot the entire car with the 2k to get an even ground coat to apply the base..I check sand with fine paper between coats to see that I have not accumulated any trash or runs..I suspect that the 2k will sand better than the epoxy in this case..
I do not use either the Kirker or Dupont so I have no clue as to their reccomendations although if the primers are well flashed the base should go down just fine....
Sam
Old 02-27-2007, 12:42 PM
I am in the process of using the Kirker "complete paint job" kit. I like the primer, although I would definately add some reducer to it in order to get it to lay down with less peel. It seems to sand real nice. Having said that I can't say I love the paint, I just can't seem to get the metallic to go on evenly. It almost makes me wish I had just clear coated the primer! But I am still trying to get over the learning curve so maybe by the time I get the last panel painted I will be able to redo it and get the stripes out...Anyway, I like the primer and haven't had any problems with it.
Old 02-27-2007, 10:37 PM
re:more prmer questions
Layzis
I would ck your spray pattern ,then overlap each pass you make
and try to keep your distance from 6 to 8 inches or so
Old 02-28-2007, 05:49 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I've had the same problem with their polyurethane, some of the
high metallic colors are hard to get to cover and lay even.
Try and spray to get a gloss and it mottles and will show as dark spots.
I solved the problem on the one I'm doing now by spraying it a little
dryer (like basecoat) and clearing with a regular urethane clear
for the gloss. And it'll be safer to buff out being clearcoated.
Questions about Evercoat Feather Fill primer. Fordy8man Body - Exterior 16 02-05-2010 12:33 PM
epoxy primer wisch79 Body - Exterior 2 02-22-2006 11:19 AM
Primer Questions & observations x711 Body - Exterior 1 01-19-2006 09:23 PM
different primers burninrubbah617 Body - Exterior 4 01-15-2006 08:14 PM
Primer hardener - sold it to me, but not on tech sheet? 58Apache Body - Exterior 5 10-15-2005 04:02 PM
