more primer questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2007, 09:33 AM
i'm putting repair panels in and painting a 70s era vw bus. front has alot of pitting. I got alot of metal work done, but still have the front and rocker areas.
i started the job with dupont 2580 Epoxy Chromate CR. I bought new supplies online and now have the following:
1 Gallon Pastel White BC (1k)-same as PPG MBC-80$
1 Gallon Urethane Clear (2k) -same as PPG OMC 161-80$
1 Gallon Primer (2K)-High Build Urethane Primer.140$
The problem I had was the paint supplier couldn't get my primer order
straight. Then the reply became "this is what you want". They shipped.
I calledback and when the BOSS started off by saying "2K" stands for epoxy,
i knew i had trouble. Then he said the primer they shipped is" THE CADILLAC
of primers and I want the CHEVY of primers, and epoxy or urethane (resins) is
just SEMANTICS". THen as if to possibly psyche me out? HE made it sound
like this 2k urethane high build primer i have was of great value, and i CAN return
this primer and he'll ship me two gallons of the epoxy i want, which is somehow
now understood to be epoxy primer sealer.??
OK now I have these products. Shipping the 2K urethane primer back, is an option, or Should i just BUY MORE of the Dupont 2580 to address the remaining rusty bleed through areas? Then use the high build opver filler? I would welcome any suggestions for another supplier as well.
Thanks
Eric
Old 10-20-2007, 12:25 PM
daoldbuick's Avatar
you wrote
"OK now I have these products. Shipping the 2K urethane primer back, is an option, or Should i just BUY MORE of the Dupont 2580 to address the remaining rusty bleed through areas? Then use the high build opver filler? I would welcome any suggestions for another supplier as well"
I'm confused as to what "remaining rusty bleed through areas" means???? Are you putting epoxy sealer over the rust???
Old 10-20-2007, 01:44 PM
the earlier primer was etch in an aerosol and wasnt top coated. so yes this is where i want to strip and recoat starting with the dupont- or like epoxy.
Questions about Evercoat Feather Fill primer. Fordy8man Body - Exterior 16 02-05-2010 12:33 PM
epoxy primer wisch79 Body - Exterior 2 02-22-2006 11:19 AM
Primer Questions & observations x711 Body - Exterior 1 01-19-2006 09:23 PM
different primers burninrubbah617 Body - Exterior 4 01-15-2006 08:14 PM
Primer hardener - sold it to me, but not on tech sheet? 58Apache Body - Exterior 5 10-15-2005 04:02 PM
