My donor carb core I bought today has a very nicely polished throttle plate. Is this likely a DIY modification, or did certain applications come from the factory this way? The casting # identifies the carb as a 75 Chevy MT.
Do you mean the butterflies are polished? If so this is a mistake. If you look at the butterflies from the factory, they have a criss cross pattern on them, this is to help mix the air fuel mixture. Often the factory butterflies on the primary side are replaced when new throttle shaft bushings are added and they use smooth ones as a replacement. When I`m building a Quadrajet one of the mods I do is rough them up good with a file.
The butterflies are still cross hatched, but the mating surface on the top and the inside of all 4 of the throats are nice and shiny smooth. My other carb had a slight texture from the casting.
This is a cruddy Q Jet I was sent from a salvage yard in CA.
All the threads in the body were shot so I drilled and rethreaded to the
nearest metric size up.
It worked until I went to a Speed Demon.
That one looks pretty smooth too. The throats on mine are a near mirror finish, was that one like that too?
The carb I have that isn't polished is a q-jet by Carter, while the other is a Rochester made. I wonder if there was a difference in the manufacturing processes between the two companies?
Someone has been at the one you're talking about. They were a dichromate conversion finish inside and out, not shiny or particularly "mirror finished". Same thing for the throttle blades. Dull-ish, as stamped and finished, not polished- at least on any that I've seen. And I've seen a few.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
