Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More Shifter Cable Bracket ?'s
Old 10-15-2012, 01:13 PM
91CamaroDude 91CamaroDude is offline
I have thought about trying to weld it, but i do not have a welder that will join brass and aluminum. I have an idea to use the mount holes on the side of the tranny and make a backing plate for the cable to prevent it from moving backwards. It will go from P - D but will not go back up into P because of it free moving.
Now if I were to try and use the clamp you have seen at hardware store, can you find a name or a picture that I can refer to?
