Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More Shifter Cable Bracket ?'s
Old 10-15-2012, 01:20 PM
bigdog7373's Avatar
bigdog7373 bigdog7373 is offline
Of course it's fast
Originally Posted by 91CamaroDude View Post
I have thought about trying to weld it, but i do not have a welder that will join brass and aluminum. I have an idea to use the mount holes on the side of the tranny and make a backing plate for the cable to prevent it from moving backwards. It will go from P - D but will not go back up into P because of it free moving.
Now if I were to try and use the clamp you have seen at hardware store, can you find a name or a picture that I can refer to?
There's no shops around you that can just put a few tack welds on there? It's not like it's holding weight or anything so it doesn't have to be super strong. I'll try to look for the thing i was talking about. I'll post a link if i find it.
Here's some i found. If you had a picture it would help. There's a ton of clamp-like fasteners on the homedepot site. Just put clamp in the search bar.
What about a hose clamp?
If you can get a picture I could help you better
