More Shifter Cable Bracket ?'s - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2012, 01:00 PM
So I eneded up getting a cable bracket - Picutre below - and it mounts up to the pan bolts. Now I got a cable - Picture Below - for a 77' camaro with a th350 and sbv8. I managed to get it to mount to the shifter just fine, but the hole on the bracket it too small to fit the cable through inbetween the bushings. I have vice gripped them together just to see if I would have enough range to shift the gears, and it works. I need some kind of C-Clamp fastener that will hold them together. Does any one know of the best route to go about this? Do they make c clamp hardware not designated for using it as a tool?
Name:	shift cable.jpg
ID:	68391   Click image for larger version
Name:	cable bracket.jpg
Old 10-13-2012, 08:22 PM
bigdog7373's Avatar
Of course it's fast
I'm not completely sure what you're asking but i know i've seen something like what you're asking about at hardware stores. Why dont you heat it up, move it to where you need it, then weld it? WOuld be a lot more secure.
Old 10-15-2012, 01:13 PM
I have thought about trying to weld it, but i do not have a welder that will join brass and aluminum. I have an idea to use the mount holes on the side of the tranny and make a backing plate for the cable to prevent it from moving backwards. It will go from P - D but will not go back up into P because of it free moving.
Now if I were to try and use the clamp you have seen at hardware store, can you find a name or a picture that I can refer to?
Old 10-15-2012, 01:20 PM
bigdog7373's Avatar
Of course it's fast
There's no shops around you that can just put a few tack welds on there? It's not like it's holding weight or anything so it doesn't have to be super strong. I'll try to look for the thing i was talking about. I'll post a link if i find it.
Here's some i found. If you had a picture it would help. There's a ton of clamp-like fasteners on the homedepot site. Just put clamp in the search bar.
http://www.homedepot.com/h_d1/N-5yc1...1#.UHxjlFF3Vf8
http://www.homedepot.com/h_d1/N-5yc1...1#.UHxjDFF3Vf8
http://www.homedepot.com/h_d1/N-5yc1...1#.UHxjRlF3Vf8
What about a hose clamp?
If you can get a picture I could help you better
Is the 4.3V6 TV cable bracket same as V8 grumpy1 Transmission - Rearend 4 01-01-2008 06:01 PM
1968-1974 Chevelle Turbo400 Floor Shifter Cable Bracket chevelle_man64 Transmission - Rearend 2 09-12-2007 06:51 PM
tv cable bracket gr8z28 Transmission - Rearend 7 08-20-2007 11:20 AM
What throttle cable bracket 406chevelle Engine 2 07-03-2004 11:21 PM
T-350 shifter bracket bowtie123 Transmission - Rearend 1 01-29-2004 09:53 PM
