| Register now (free) or login to remove ads | |
Tweet
| Sponsored Links |
#47
One of these days I'm going to try this......
#48
When you’re ready shoot me a line at automotivebreath@hotmail.com: I'll help you get started. Last night I was getting ready for first round of the Friday night races and I got a call from Mark, a long time racer/hot rodder. He had installed his 355 with these Edelbrock RPMs in his project 63 Nova. He is very familiar with the engine it came out of his previous street rod. He fired it up for the first time after installing the modified heads. He couldn't believe the difference. With a 280 degree Isky hydraulic cam the engine now idles cold at 500 RPM with no choke. Throttle response is crisp and instant.
#49
That by itself would be pretty cool. Something, is definatly going on inside there.........Will do.....
#50
What determines where to place the grooves?
#51
I conclude flame speed is much faster. Conditions in the cylinder and in the exhaust port near the valve at the end of the exaust stroke are much different, this has a positive impact on the intact tract during overlap. Last edited by automotive breath : 03-17-2007 at 09:59 PM. |
#52
For the most part the valves limit where grooves can be laid out. Most multi groove heads that you see from me are either my thinking or ideas I get from others. |
#54
Hi Lil Big Mec, Somender Singh uses a hand held hacksaw blade and a file. I tried that once and it was too slow for me. I know other people that use a high speed cutoff wheel. I tried that too but was too nervous that I might mess up. So I developed my own method, I don't have a mill so I fabricated a jig that allows me to cut a straight line with my high speed grinder. I use a 1/16" ball end mill to cut the initial groove, I then widen and deepen the groove into the chamber with a file. The most important part is to layout the bore size on the head to assure the gasket seal area is not damaged. I mark the bore diameter and lay out the grooves with a felt tip marker as shown. ![]()
| Similar Threads for: "More Singh’s grooves" | ||||
| Singh's Grooves in Ported & Milled vortec heads on stock 350 | automotive breath | Engine | 204 | 01-31-2007 08:38 PM |
| Saginaw 4speed Question | razdude | Transmission - Rearend | 6 | 11-07-2006 06:08 PM |
| ? about the groove's on the input shaft. | bowtieorbust | Transmission - Rearend | 2 | 06-19-2004 09:48 AM |
