More TH 350 help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2005, 05:25 PM
stea's Avatar
Ok, started this thread a couple weeks ago. http://www.hotrodders.com/t65578.html
I decided to try the easy stuff first. Changed the vacuum modulator. No change still would not shift up from first.
Today I pulled the governor and the plastic gear was stripped. I replaced the governor and fully expected to work, but guess what, still no up shift. Have good vacuum to the tranny. Any ideas?
Old 07-30-2005, 06:37 PM
adtkart@aol.com
Since you already had a post on this problem, you should have stuck it out there, not posted another post. That way people would have known what was recomended and checked. They would not have to go back to another post to check that info.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
327or 350 70 nova Engine 5 07-27-2003 10:14 PM
