Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More TQ than HP???
  #17 (permalink)
Old 10-29-2012, 11:32 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
aluminum heads cool better so they will tolerate more compression with other items remaining the same.If you keep that small cam I see no reason to go very big on the intake runners.180s are good enough.it depends what the heads flow,how many cfm the heads flow at what valve lift,then factor in your cam and see what you can make HP wise
