Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More TQ than HP???
  #22 (permalink)
Old 10-29-2012, 04:56 PM
Caballerokid's Avatar
Caballerokid Caballerokid is offline
Ya the build is a little goofy. The pistons are .040" in the hole which is how i have .055" quench. That is some great info on those heads! I have the ports opened up pretty good at the mouth but just the way they are cast you can tell they are restrictive. I'm looking at a set of TrickFlow fast as cast 72cc aluminum heads with 180cc runners and 75cc exhaust. Those should really help the flow out along with the 2.02 int valves. I'm going to notch the intake plenum and add an open 1" spacer which should also help. Then see where i go from there. What do you guys think? Thanks!
