Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More TQ than HP???
  #26 (permalink)
Old 10-29-2012, 05:26 PM
cdminter59 cdminter59 is offline
More TQ than HP???
Yeah, that's the part I don't understand. A 350 chevy block has a deck height of 9.025. Add 1/2 the crank diameter, the rod length, and piston compression height on your pistons. The total comes to 9.0". How can the pistons be .040 in the hole? The Trick Flow heads have a 72cc chamber, that will put your static compression at 10.571 and the DCR at 9.493. You will have to use 110 octane with a DCR of 9.493.
