Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - More TQ than HP???
  #41 (permalink)
Old 10-30-2012, 04:47 PM
ap72 ap72 is offline
Banned
If you're going to go through the trouble of increasing the gap on your rings I'd swap in some flat top or dished pistons while you're there. A good set of used pistons would work if you're careful.
Then again you could just swap your cam into a used stock long block, which you can often find for a couple hundred bucks.
