If I were to get better heads and improve the flow, I could bring up the HP figure and the torque figure would more than likely come up equally if not more in relation to the HP number? So I guess I'm saying, would it be possible to squeeze 350 hp and 400-425 tq with this cam but better flowing top end?
I would guess your flywheel HP is about 300 right now. A head change could pick you up as much as 50fwHP. The low rise Performer and small headers are going to keep the max HP knocked down, as will the 650 carb. But, those parts do tend to keep the torque up which makes a more street friendly engine.
A small problem is that you have a 3.5cc dome, and most performance ehads come in at 64cc's. There are a few out there with larger chambers but your selection is more limited. Also, was this enigne dyno tuned or just ran on a dyno? If it wasn't properly tuned you could have an easy 20+hp right there. With your highway gears I wouldn't worry too much about peak power though and focus more on getting as much tq/power as you can between 2,000 and 4,000 rpm as that's where you'll be doing most of your driving. |
It was half way tuned by me which was ok but nothing professional and it was in the car on the dyno. So those numbers where to teh wheels. Also, I already have 1.6:1 roller rockers. The rpm air gap won't make a difference accept at high end. I am thinking of modifying the performer intake (cutting a notch out of the center between the two planes. I have seen dynos pulls confim about a 20tq and and 10-15 hp gain and adding a 1" carb spacer to get a little more top end. As far as the heads I'm thinking 180-200cc intake runners, 72cc heart chambers, 75cc exhaust ports and port matching to the intake. Haven't decided aluminum or cast yet. I'm hoping to squeeze another 100 hp from all of this and then possibly thinking another 100-150hp nitrous shot to make things a little more interesting
And yes the RPM intake will pick up the most at the top- that's also where you're hp peak is so if you want higher peak numbers that's exactly where you would need to pick it up. It'll also better match a good set of heads and you can pick up a used RPM intake for $75 or less. You should also tune your carb on the dyno, its the only place you can get an accurate measurement throughout the power band. and remember tuning for WOT is done through the PVCR's NOT the jets. jets are used for tuning at cruise- most people don't understand that. Getting a better tune would probably be worth a lot on your current combo and would be a necessity if you got all those other parts. It makes one hell of a difference. |
The main advantage of 1.7 rocker arms over 1.5 or 1.6 rocker arms is faster valve acceleration rate off the seats for more cylinder filling for increased low end torque. The valve duration would be increased slightly by four or five degrees.
The increased flow and HP produced with 1.7 rockers at high RPM HP is negligible. The low end torque increase may not be worth the effort it takes to fit the 1.7 rocker arms, i.e: valve spring open height, valve train geometry, pushrod clearance and pushrod strength. Higher ratio rocker arms moves the pushrod about .060" closer to the rocker arm pivot point and places more lateral load on the rocker stud and pushrod. The rocker studs should be ARP 7/16"-20 when used with 1.6 or 1.7 rocker arms and the pushrods should be .080" wall, 5/16" chromemoly. |
your cam is too small, use a 750 double pumper. what size primary tubes on the headers? a mild 330 horse 350 is going to have higher torque figures that engine is doing what it should with those parts.
usually if you use 1.7 rockers on a small block,the stud needs to be relocated. your cam needs more duration more than more lift.use a cam that allows 6200 rpm and the hp will rise |
More low end torque, meaning: Is five or ten lb. more torque at low RPM worth the cost of the changes that would be necessary to install 1.7 rockers.
You don't need more torque so don't consider 1.7 rocker arms. More cylinder pressure = more low end torque..... More cam duration = more high RPM HP Last edited by MouseFink; 10-29-2012 at 10:57 AM. |
He either has to give up power where he uses it for power where he wants it (a dumb but often followed idea) or get a cam with relatively as small duration but more aggressive lobes. keep in mind he's running crappy 882 heads with an untuned carb and 2.73 gears... To solve this whole problem I'd just give up on peak power numbers (they're meaningless on the street) and focus on getting your midrange as high as possible. Build for where you drive, not for the dyno sheet that rides in the glovebox with you. |
IMCA call a camshaft like that a "short track cam". High lift and short duration similar to my roller tappet camshaft..206/210 duration; .500" valve lift using 1.5:1 rockers and 112 degree LSA with "crappy" heads. .
I thought the op wanted more horse power. the engine is operating correctly.enjoy it |
