More turbo 400 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2006, 04:57 PM
MAD BOWTIE's Avatar
New Member
Last journal entry: At the track
I just replaced the sprag in my reverse manual valve body 400 and all was fine. About a week ago it started getting slow to take reverse, I could pull it into reverse and it would hesitate a second and then be fine. It shifts perfectly and it pulled fine in reverse until today. Now when you put it in reverse it moves a little then stops and will not move any more. It still shifts firmly from 1st to 2nd and then into 3rd but it will not move but about a foot in reverse and then will not pull any more. The trans fluid looks and smells like it just came out of the bottle. What do you think bad clutches, fluid problem Please help this thing has been the most unreliable thing I have ever dealt with Thanks for any and all help.
Old 04-03-2006, 06:33 PM
Depending on the vavlve body manufacturer, you may have a hydraulic problem. Some valvebody makers use a vented accum. circuit to allow the rear servo to apply. Does it apply reverse firmly, then fade, or does it slip on apply also?
If so, suspect a band or servo problem.
Line pressure tests would help...
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Turbo 400 help, Need to know what I did wrong MAD BOWTIE Transmission - Rearend 8 12-28-2005 08:39 AM
700r or turbo 400 yosimdisam Engine 5 02-13-2005 11:02 PM
turbo 400 problem JamesRS Transmission - Rearend 13 10-03-2004 04:27 PM
7ooR4 vs 400 turbo? WBhunter Hotrodders' Lounge 4 04-25-2002 01:54 PM
