more weiand 144 ?'s - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2008, 10:36 PM
more weiand 144 ?'s
OK so I"ve been reading a ton of stuff online and seem to find a million different opinions on these things. From what I've read here some of you acutally have experience with this blower. Here is my setup
77 2wd k5 blazer
77k orig 4 bolt motor
weiand 144
Crane Cams 113801
http://store.summitracing.com/partde...1&autoview=sku
roller tip rockers and gasket matched heads (soon to be changed)
My questions being
how many hp I can expect? I'm guessing around 350?
can I use my quadrajet until I can get some more $$ for a new carb?
any tips for tuning? timing ....
Thanks in advance for any help
Old 11-13-2008, 05:28 PM
Oh yeah and it will be running about 6 lbs boost. thanks
Old 11-13-2008, 05:36 PM
T-bucket23's Avatar
Wiki Edits: 26
You can expect about a 35% gain with stock pulleys. If you have cast pistons you are playing with fire. Blower motors like more initial timing and a total of about 38. Any carb you use will need to be setup for the blower to work properly and protect the engine internals.
I have a 142 and the difference between the blower and the NA engine was unreal. I destroyed my cast pistons with a litttle to agressive timing curve. What is your current compression ratio. 9:1 is about the max you can have with stock parts or you will blow it up.8:1 is a better starting point.
Chet
Old 11-13-2008, 09:47 PM
Thanks for all the info guys I really appreciate it.
I forgot to add I did install a holley blue fuel pump and new fuel lines as well as hv oil pump et... . I realize running a stock bottom end probably isnt the most reliable setup but this is just a weekend cruiser not a bracket car so I hope it will hold up.
I'm not too sure what stock hp numbers are so I'm really not sure what to expect for a gain. Is a 350-375 hp with just these bolt on's a reasonable goal?
Old 11-16-2008, 12:07 PM
anyone have a guess?
Old 11-16-2008, 12:53 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I too had a 142. I bolted it on a 350 and also noticed a huge difference in power. It seemed like a whole new engine. I had to be careful though because my engine had 9.7:1 compression to start with so I had to mix 114 octane gas to keep it from detonating. I drove it fairly hard for two years like that, with the stock crank and connecting rods.. Unfortunately I sold the truck and who knows what condition it's in now...
?'s on eng.tranny.rear Cape Cod Bob General Rodding Tech 3 04-21-2008 09:41 PM
Proform HEI distributor- mech adv. ?'s lumberjacknooj Engine 9 07-17-2007 05:49 AM
How far in should the slip yoke be? & Driveshaft ?'s Deezildennis Transmission - Rearend 2 06-30-2007 04:09 PM
computerless 89 Lo3 firechicken ?'s gone2fast Engine 0 07-26-2003 10:49 PM
A few ?'s bout a chevrolet 350 engine Nos Engine 11 04-20-2003 08:55 PM
