Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Moroso Electric water pump ????
Old 12-04-2004, 11:27 AM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
The type of pump you have is designed for race only, not continuous use. I agree with the others, I would not run that pump on a street car. If you really want an electric pump, you would be much better off with a CSI or Meizere. As mentioned above it really isn't worth the extra expense for what little you gain. The Moroso pump does not move much water and if you run that motor continuosly it won't last long.
Royce
