Moroso oil pan hole size in kickout? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 08:26 AM
v8hed's Avatar
AK427
I've just installed a Moroso #21803 pan and there's an open threaded hole in the kickout on the side of the drain plug. I presume this is for an oil temp sender? I'm already using the port above the filter for oil temp, so will need to plug this hole in the pan. Can anyone tell me what size plug I'll need to order? I've tried e-mailing Moroso, but didn't get a response and tried calling them, but couldn't get through after 15 mins on hold.
Old 03-26-2012, 05:14 PM
FWIW out of curiosity I looked at Summits website for MOR-21803 and got nothing. Saw a 21308 and on its instructions it notes a threaded hole used for a dipstick adapter(1/4"NPT).
ssmonty
Old 03-26-2012, 05:18 PM
v8hed's Avatar
AK427
This is the one...
http://sdparts.com/details/moroso-performance/mor21803
I think it's discontinued since it's not on the Moroso site. I got mine as new old stock. Pretty tough to find a 1pc low-profile pan.
Old 03-26-2012, 05:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Try the hardware store..most likely it is a common pipe size like 1/4 npt or maybe 3/8 npt.. my local store has lots of those kinds of pluge in either brass or steel..
Sam
Old 03-26-2012, 05:33 PM
v8hed's Avatar
AK427
I'm in the UK where we're metric (mostly), so 'imperial' sizes have to be ordered-in specially. The hole ID measures around .720", but I'm not sure what that corellates to in terms of plug size... 11/16? Doesn't sound right.
Old 03-26-2012, 06:09 PM
Wiki Edits: 3
That size sounds close to 3/8 pipe size but oh well..in your case then pick up a pipe tap of an appropriate siz and a plug..rethread to meet the size of plug and hole and screw it in with some pipe sealer and done deal...We have those kind of details to fix on our hotrods on a regular basis here..the alternative if you are never foing to use that hole is to just weld a piece of metal on the inside of the pan to close off the unused hole..
Sam
Old 03-26-2012, 07:43 PM
OLNOLAN's Avatar
??? Npt
Hey Man, Like your car. I think you'll find that its 1/2 NPT threads. If you have a thread pitch gauge(US standard) look for 14 TPI. The pan on my boat engine has the extra holes for sensors and I'm almost sure they are 1/2"NPT. Your measurement sounds real close;http://www.engineeringtoolbox.com/np...ads-d_750.html
Try a 1/2" NPT plug in it, you may be able to find one in your part of the world. olnolan
Old 03-26-2012, 08:39 PM
4 Jaw Chuck's Avatar
National Pipe Thread (NPT) is an international standard tapered thread, you shouldn't have to order it. There is no metric equivalent although there are other kind of tapered threads.
Have you asked for these type of pipe plugs locally?
— Han Solo
Old 03-27-2012, 12:25 AM
v8hed's Avatar
AK427
You're the man! V.useful chart... looking at that, you're right, it has to be 1/2" NPT. I'll get one sorted.
Thanks!
Old 03-27-2012, 01:52 AM
v8hed's Avatar
AK427
Thanks!
stripped hole by steam hole one 400sbc projectman69 Engine 11 11-06-2011 08:30 AM
2 hole exhaust flange connecting to a 3 hole JLBpontiac350 Engine 0 04-26-2011 01:31 AM
Cracked steam hole going to bolt hole projectman69 Engine 4 11-10-2010 06:54 AM
moroso oil filter sapsz28 Engine 10 05-09-2009 02:08 AM
SBC Moroso Oil Pan Rad Ray Engine 2 12-25-2002 03:50 PM
