Just to give you guys a heads up, if you havent already encountered this.
I was using this moroso throttle cable bracket and went to put my new speed demon with VS and electric choke on top of it. Well, it was wobbling back and forth as if either the baseplate or intake was out of true, so I took the throttle bracket off to put just the carb on there, and it was fine. So I thought the thottle bracket was warped.
I put a straight edge up to it, and everything looked fine.
So I put it all back together, looked all around it and found that some of the linkage on the choke side was not clearing the plate. So I just took the gasket as a reference and notched out that side of the bracket with the trusty dremel. Took friggen forever, lol.
Dont know if it will do this with holleys or not, but this is the first time Ive ever had a bracket like this.
Just thought I would give everybody a heads up on this who plan on using that bracket, and a similar carb.
