Morton primer surfacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2006, 01:08 PM
Has anyone ever used Morton Easy Fill urethane primer? Work good?
I can get a gallon for $90.00 and seems like an economical alternative to PPG.
Do you guys stick with one brand for primer to top coat?
Thanks
Old 07-08-2006, 01:18 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Welcome 68... I used a gallon of the Morton before.. I had sand scratches come back on me down the road... I sanded my filler work with 80 and no finer...
I think if you sanded you filler work with 180 and prime, block 180, prime, block with 400.. you should be fine... Dont forget to guide coat... very very important
Old 07-08-2006, 08:25 PM
Cool, thanks for the reply. Maybe I should just stick with PPG.
Thanks
Old 07-08-2006, 08:56 PM
I've used a few gallons of that stuff in years past. In my opinion you've got some way better options available. It sands a heck of a lot harder than most urethane primer surfacers and wetsanding is poor. This primer is a strange duck IMO with a slow rate of cure. Just my opinion though, I'm sure others may disagree. Bob
Old 07-08-2006, 09:47 PM
What would the way better options be; should I stick with PPG and if so would you recommend the K36 or K38 or maybe something out of the Omni line?
Thanks
Old 07-09-2006, 08:32 AM
After using the Morton and comparing it to others I wouldn't recomend it. K36 is good and has proven itself for years, K38 is also good and has been around for quite awhile now. NCP270 and 271 work well IMO. Omni MP182 works but does show more shinkage than 36 and 38 IMO, Omni MP282 SV is some easy sanding high build primer with no shrinkage problems that I've seen when I tried it. Omni products are budget orientated and supposedly have a shorter lifespan that Global, Deltron, and Nexa PPG products. No warranty with Omni.
Or you could go with SPI Southern Polyurethanes Inc for top notch quality primers at reasonable prices.
Marhyde, Transtar, U-tech, Valspar, Nason, Keystone... also offer economical alternatives. There's many to pick from.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Evercoat Slick Sand, Featherfill, G2, Polyester Primer Surfacer scrot Body - Exterior 6 05-27-2006 02:27 PM
Sealer over 2K primer surfacer, yes or no? wreckedGTI Body - Exterior 10 11-17-2005 03:35 PM
Orange peel in 2K primer surfacer wreckedGTI Body - Exterior 10 08-22-2005 12:24 PM
omni mp282 sv high build primer surfacer & dbc #1berettaman1991gtz Body - Exterior 12 07-28-2004 06:44 AM
