Most Important Tools - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2004, 05:44 AM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Was just down in my shop thinking to myself at what next piece of equipment I should buy next (just picked up a chop saw today) and ideas are getting harder as the years roll on. Here is what I got now:
Compressor
Drill Press
Chop Saw
Vice
Mig Welder
Arc Welder
Battery Charger
Chain Blocks
Bench Grinder
Hydrolic Jacks
Jack Stands
Engine Stand
2 Rolls Cab And 2 Top Boxes Full Of Hand Tools
Was thinking about a power washer or parts washer in time
Whats in your garage?
Old 10-29-2004, 10:31 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
You need a plasma cutter!
Old 10-30-2004, 11:44 PM
MI2600's Avatar
Member# 3287
I didn't see any duct tape!
Old 11-01-2004, 04:47 AM
Old enough to know better
The plasma cutter is a good idea. Another tool I added a while back is a 20 ton shop press. I don't use it a lot but, when you need it, there is just no good substitute. Watch the Harbor Freight sales and you don't have to spend a whole lot for one.
Old 11-01-2004, 05:11 AM
poncho62's Avatar
Wiki Edits: 5
cordless drill.
Old 11-01-2004, 06:05 AM
thewrongshop@yahoo.com
Plasma cutter 120/240 volt
Mill Drill Lathe
Bench Grinder
AD/DC Gas powered arc/welder/ generator/
Mig Welder
Port-A-power
Cordless Drill 14 volt +
Uni -Bits
Die Grinder
4 " Disc Grinder
Battery Charger
Torch Set
Engine Hoist
6" Vice
7Hp/ 60 Gal. Air Compressor
Tool Box & tools
Port-A-Band Saw
Saws -All
Any tool that has an air hose or electric cord
Refrigerator
Paint Spray guns
DA Sander/s
Taps & Dies
Drill bit set
Flange/Punch tool
Body Hammers
Floor Jack/s
4 Jack Stands
Racing Tape
Pressure Washer
Did I mention a Refrigerator ...
I didn't enter this before but it is a factor.
radiant propane heat & air conditioning..
yes I have it
Old 11-01-2004, 09:39 PM
One more (depending on geographic location) : Furnace or heater!
Old 12-04-2004, 11:05 PM
superrodder's Avatar
A cute girl in short shorts and a halter top to do your work for you
Old 12-05-2004, 05:26 AM
fourbyfourblazer's Avatar
Chopper Builder o<>\o
Last journal entry: Dash Removal
Naww. that's probably not a good idea unless the quality of your work isn't important. Just let her bring you drinks and tell you how great you are.
Don't forget a sandblaster, ironworker and anvil.
Old 12-05-2004, 01:42 PM
dmc12mk3's Avatar
Last journal entry: Fixed some leaks
A lift is extremely handy if you plan to work on cars. Which, I don't suppose you would be here if you weren't (grin). Arguably the best 2000 dollars you'll spend for a shop upgrade.
