-   -   moter switch for 1993 gmc k1500 (http://www.hotrodders.com/forum/moter-switch-1993-gmc-k1500-218628.html)
bigtom1960 04-25-2012 06:21 PM
i have a 93 k1500 with a v-6 tbi moter , can i put a 305 tbi moter from a 91 gmc 1500 two wheele drive in its place ?
1996thunderchicken 04-25-2012 09:16 PM
should be able to may have to switch where the motor mounts are located should have wholes in the frame to do this with out hassle
nine4gmc 04-25-2012 09:29 PM
you gotta drop the front suspension and pull the coils out to access the inside nuts of the motor mounts. it sucks bad but other than that and the wire harness, the swap is pretty easy.
joe_padavano 04-29-2012 10:50 AM
You do realize that if you plan to keep the TBI, you need the injectors and computer for the 305, right?
