moter switch for 1993 gmc k1500 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2012, 06:21 PM
i have a 93 k1500 with a v-6 tbi moter , can i put a 305 tbi moter from a 91 gmc 1500 two wheele drive in its place ?
Old 04-25-2012, 09:16 PM
1996thunderchicken's Avatar
ALL AMERICAN MADE
should be able to may have to switch where the motor mounts are located should have wholes in the frame to do this with out hassle
Old 04-25-2012, 09:29 PM
nine4gmc's Avatar
you gotta drop the front suspension and pull the coils out to access the inside nuts of the motor mounts. it sucks bad but other than that and the wire harness, the swap is pretty easy.
Old 04-29-2012, 10:50 AM
You do realize that if you plan to keep the TBI, you need the injectors and computer for the 305, right?
1993 k1500 suburban 4x4 jekedeves Transmission - Rearend 1 01-18-2012 08:12 PM
'89 GMC K1500 vacuum diagram? MAUSS Engine 1 12-23-2011 07:58 AM
Canton Ohio 1995 GMC K1500 WVtrout Introduce Yourself 3 01-22-2009 12:12 PM
1993 Silverado K1500 auto to manual trans swap.. FinishLine Transmission - Rearend 1 01-11-2009 08:42 PM
1993 Suburban k1500 Transmission upgrade dlac1769 Transmission - Rearend 3 10-23-2004 07:26 AM
