motor coufing splutting stalling after starting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 08:49 PM
hi there guys,im a newbie and 1st timer slowly tryin to fix up old 72 fairlane. i jst changed trans c4, and fixed up starter mtr, motor is a 351 cl.last week she was running nice, idle was good i had not noticed any leaks, then 3days ago she started making a weird as noise, from under rocket cvr, then it quiten down, and now shes coufing spluttering starts sounds like crap then stalls, i see puffs of gas poping up out of carb 600 holley, and up the fnt float a small leak, took plugs out scooty as, ive got no sencors, and i need to get vaccum , sorry if i sound a bit scattered,hoping some one can steer me in right direction or let me kw where to start investergating...cheers tokaanu.
Old 03-17-2013, 11:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It sounds like the carb might be flooding the engine.
You MUST fix the gas leak or risk burning it to the ground, I would start w/rebuilding the carb, replacing the fuel filter and tuning it up. Then take it from there.
Old 03-19-2013, 03:05 AM
first rebuild on carb...
thanks cobalt327, jst tracked me dwn a rebuild kit,will do rebuild on weekend, holley was a 500 nt 600 my mistake... thanks let ya kw when ive finished build an tune.
Old 03-19-2013, 04:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Is it a 2 barrel? I don't know of an aftermarket Holley 500 cfm 4 barrel...
Anyway, if it's an aftermarket carb (not a production Ford Motorcraft, Autolite or Holley), you can take the number stamped into the front of the choke tower and look it up here. An example of the number to look for is 1850, or 3310.
Good luck.
Old 03-19-2013, 06:19 AM
33Willys77's Avatar
What did the noise sound like? Possible cam, rocker arm and/or valve issue too. May want to consider a compression test.
Old 03-19-2013, 06:38 AM
Is your distributor tightened down? It might of moved causing the timing to be off. If you have gas coming out of the tail pipe then one of the cylinders is not firing and the gas is being forced out the pipe. Do you hear popping? That would be excessive gas in the exhaust. Check that all the wires are connected tight at the plugs.
Old 03-19-2013, 07:28 PM
hi again carb is a 2barrel, i gave list number to partsman, he has kit for the list number....thanks 4 the info on holley carbs interesting as...1st time rebuilding a carb, but ive ben studying how they build them on line, so il take my time, an try an keep things organised thanks mate,il let ya kw when done..
Old 03-19-2013, 07:43 PM
hi there 33willys77, that noise i herd sounded like taping ratling noise then it seemed to quiet,n down, shut her off, started her up 10mins later noise still there but with an added sshhh....sshhh....sshhh sound shut her down went on line to see if i could find out whats happening, come bac with what you have posted, so now im looking to get a compression test,but i think il rebuild this carb 1st thanks man. anymore help is much apprecited.
Old 03-19-2013, 08:30 PM
33Willys77's Avatar
Make sure your timing is good, carbs are not flooding over, and do a compression check. Start there.
thanks johnshennouda ,i checked dizzy bolt was a bit loose,then checked all the leads they were good...but when i went to check the1 in the middle of dizzy, or though it looked tight on, i pushed dwn on lead and it went in 5mm, so i try for a start she started better than the other day, however she started stalling an all again, and i think timing is an issue too, but im a bit of a green horn so il start with rebuilding carb as cobalt327 sugested an go from there...thanks for you info, gave me a spark to her fire up even tho it wasn,t long,anymore insight mch appreciated cheers..
Old 03-19-2013, 08:43 PM
thanks 33willys77, will do, il try track down compression tester,and go over my timing ,thanks tokaanu.
Old 03-20-2013, 06:18 AM
After further thought, I think what you should do first is simply change out the plugs. At least the no.1 plug. Since the wire was loose and it was not firing it probably got fouled up. Very cheap fix. Start there.
Old 03-25-2013, 04:04 AM
fireing order not right.
hi there guys sorry for late post, gt called away for work, out a town, cheers for all the info, i looked at my timing, low and behold i had leeds going to the wrong plugs, have put them rite, cleaned up plugs,new rotor cap, new feul fillter, and getting new leeds as well, started her up and she came right and sound relly cool....still a bit a noise under rocket cover.had a bit of smoke com,n from exhaust manifold connection, pulled it out sunday donut gasket was cracked so ordered new ones,ganna chuck dem in easter.also gt rebuild kit for carb, and compression kit on the way.thanks heaps men for your help i hope if i get stuck again, and i will, i can ask for some advise thanks cobalt327 33willys77 johnsenouda kind regards tokaanu.
tahoe cold starting/stalling problem ChevyJim Engine 17 11-13-2011 09:00 AM
Need help with stalling and starting please Mike Watson Engine 1 09-11-2011 02:11 PM
T-400 stalling motor when selecting drive PULSE Transmission - Rearend 7 08-24-2011 08:58 AM
starting old motor jetnow1 Hotrodding Basics 36 09-04-2010 07:13 PM
Starting your blower motor? How do you? DUKEOFBLUZ Engine 4 05-07-2007 11:44 AM
