Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Motor flattens out at 5k
Old 01-11-2013, 02:16 PM
fatgump fatgump is offline
Originally Posted by hcompton View Post
Whats the cam duration at .050?
Did you use lifters and springs made for this cam or stock. It sounds like you should eaisly hit 5600.
Have you tried to move the rev limiter up to higher rpm or take it off and see if it still wont rev.
Does it just flatten out or does it studder out like rev limiter. Also do you have a soft rev limiter. Some will hold the engine at certain rpm without the poping and shutter of old style rev limiters.
It just flattens out.
Originally Posted by cdminter59 View Post
Do you have the matching springs for the Lunati cam or just the springs that came on the Dart heads? You might be having valve float. Also check your timing adjust the initial to about 16*-18* at idle and rev it to 3000 rpms and hold it adjust the total to 36*. Have you changed springs in the distributor for the mechanical advance? If not use 1 light spring and 1 medium spring, this let the mechanical advance come in sooner. Does this MSD distributor with vacuum advance have a part#? I hope it ain't the cheap StreetFire 8362!
I am running dual springs that came with the Darts. My timing is at 35@3000 RPM. I have the MSD 8361 Pro Billet.
