motor was given to me. need info... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2011, 07:29 AM
i just had an old R.V give to me. I was told it has a 327 in it. I don't know a lot of details on it right now. but i do know the block number is 3970010. i looked it up an found out it is from 1968-1979 hp levels are 145-375 hp. a they come in 2 an 4 bolt mains. also this block shows it was used for 327 an 350cid. i guess my question is how can i tell what one it is. or can you with out pulling the pan an running the crank numbers.I'M praying its a 327 cause i already have a 350cid with this number and a 400cid. but always wanted a 327 just so i could say i have one lol.any comments would help. Thanks
Old 09-21-2011, 08:13 AM
TroyBoy's Avatar
Psychomotors
Just curious about the year of the RV. If its a 327, it will be a 2 bolt main but it could still be a 350. There is a machined pad on the block-passenger side front where the head attaches to the block, that will have the serial number and a letter code stamped into it. Some of the guys on here will probably be able to decode these for you. Yes to the question about the crank numbers but it would be a big pain in the butt if the engine was still in the RV.
Old 09-21-2011, 08:22 AM
not sure of the year just know it was an old one. im going to get it today an i'll try an get the numbers on the front of the block. the camper is junk the plan was just pull the motor an trany an junk the rest.
Old 09-21-2011, 12:39 PM
TroyBoy's Avatar
Psychomotors
Might be able to sell the rearend to a 4x4 guy.
need help finding out info and specs on motor and heads hplus8 Engine 4 05-01-2011 11:11 AM
HO 350ci 350 crate motor info trog Engine 9 01-22-2011 02:23 AM
Caddy motor cant find cid info help creativeinteriors Engine 3 07-17-2004 05:34 PM
Mexican 350ci Motor..Info? 1BDMNTY Engine 32 03-23-2004 09:17 PM
NEED INFO 55 chevy v8 Side motor mounts Dave Y. Transmission - Rearend 3 12-20-2002 11:23 AM
