Motor idea changed again... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2012, 12:48 AM
Hey guys, I again changed my idea for my combination for my motor. I did more digging and came up with a 400 4-bolt main block with ARP bolts, punched .030 over, decked, and line honed. A comp 300AR solid roller (12-705-8 - Magnum), H634CP30 pistons, scat 4340 I-beam rods, and an eagle cast steel crank. For the heads, I ended up with a set of ported Brodix track 1's, and either a Team G or Bowtie single plane intake. With an 830 carb on E85. I know the cam is on the small side, but I'm not trying to squeeze every bit of power humanly possible out of this combo yet. But any other opinions would be appreciated.
Old 08-19-2012, 08:24 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Is there a question in here somewhere or just a statement?
Old 08-19-2012, 09:15 AM
sorry, wrote this when I was extremely tired last night. I was wondering if anyone has used a combo similar to this. If so how'd it work out? Also if anyone had any advice on this whole combination.
Old 08-19-2012, 09:20 AM
vinniekq2's Avatar
I use a similar camshaft in my vette.not sure what power you will end up with using e-85?
Old 08-21-2012, 12:22 PM
how'd you like the cam?
Old 08-21-2012, 01:27 PM
I have reservations about the survivability of the Eagle Cast Crank. I expect you'll be over 500 HP (that's off the top of my head, though) and I don't think cast crankshafts hold up too well in that environment.
PatM
Old 08-21-2012, 03:36 PM
vinniekq2's Avatar
my cam is a comp solid roller. makes very good power from 2500 to 4000,then from 4000 hang on!!!!I put a 6k chip in the rev limiter to keep the car straight on street tires. The car will also lope along at 65 mph turning about 2200 rpm in high gear. rough idle,,,950 rpm
67 GTO, LeMans body. Good Idea? Bad Idea? GoatGuy Hotrodding Basics 54 06-08-2011 10:54 AM
Good idea? Bad idea? smharbert79 Engine 2 07-18-2009 11:27 AM
I have no idea what logic was used to build my motor... advice..? camaroguy72 Engine 3 11-11-2008 09:09 AM
changed plugs and now the motor is missing 71javelin Engine 8 12-10-2006 06:30 PM
1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea. 1969css Introduce Yourself 1 12-22-2004 05:18 AM
