Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - motor locked after installing c4 trans
Old 01-31-2013, 04:18 PM
alkey alkey is offline
motor locked up
sounds as though front pump and torque converter are not aligned.unbolt torque converter from flex plate and see if you can move converter toward transmission,also try to rotate engine. could have damaged front pump if they werent aligned.
