Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - motor locked after installing c4 trans
Old 01-31-2013, 06:09 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Can not rotate converter on C4 application, although there should be movement as mentioned. Converter studs protrude thru the flexplate during install.
Is it possible the converter was bolted to the flexplate first , then the trans installed on to the engine? If so... broken pump is the result.
As it sit now, sounds like a broken pump may have happened
