Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - motor locked after installing c4 trans
Old 02-03-2013, 01:41 AM
mmerlinn mmerlinn is offline
Wiki Edits: 85
Originally Posted by rick 427 View Post
I don't know what year trans you got....65-69 pumps will interchange.Then 70-77.Then 78-81,followed by 82-86.
65 and 66 pumps used an o-ring seal. All later versions used a gasket seal. Using the wrong type can result in leaks.
70 to 81 all directly interchange. Only difference is sealing ring width.
OP. No specialist tools needed. It is possible, though unlikely, that your pump is ok. Check it out before you replace it.
Also check the converter snout. Sometimes it can get damaged in situations like this. Check your bell for cracks, especially around your motor bolts.
If your input shaft does not slip out easily, you could have damaged your forward drum.
